VPN on RBR50?
TeamZero
Is it possible to set up a VPN on this, so everything connected goes through the VPN? I was thinking ExpressVPN or Nord
Yes of course. It is described in QuickStart.txt
13. WireGuard client.
To start its using you should
or
14. OpenVPN client.
Important: only TUN clients are supported
To install OpenVPN client you can use two methods. First, semiautomatic:
Voxel.
