VPN on stock or custom?
Ancaster
I'm new to VPN, bought one for my friend's bday and thinking of buying PIA VPN for myself.
Instead of single device setup, I want to set it at the router level.
Can I set this up on stock?
Or do I need to flash custom FW?
If so, FW recommendations?
And is it easy to toggle between default and PIA?
I apologize for my ignorance.
I've had my N66 2 months now and love it.
You will need a custom firmware for this. There is no VPN client in the original firmware.
Tomato and Asuswrt-Merlin will both give you OpenVPN support for this service.
Think I'm going to use yours Merlin, which build should I flash?
The latest found on either Github or my website is fine. Just pick the one specific to your router model.
