VPN Options
Jamie96
So i was just wondering is there any benefit of running a vpn from the router over say software on a firestick? and if so what's the best protocol to use openvpn or ipsec?
OzarkEdge
Part of the Furniture
Do you mean a VPN from a Firestick dongle on your TV to your router?
OE
OzarkEdge
Right now I run the vpns own app on firestick which works fine just wondering would it run better from the router and if so what's the best protocol?
Assuming you are using a VPN service, perhaps they can recommend protocol and usage.
OE
L&LD
What is your ISP paid for speeds u/d?
What router do you have? What firmware is installed?
What speeds, issues, or bottlenecks does using the VPN now cause that you want to alleviate?
Jamie96
500 down haven't a clue what upload is on speed tests it's 36.
Asus Rt-ac86u Asus firmware recent
It works well for what I need it for iptv but was just wondering would running it straight from the router be better than on the firestick itself.
