I am using ASUSWRT-Merlin RT-AC68U 380.69.
What I wanted to do is to have my TV using VPN and the rest of the network normally. So I used redirect internet traffic and select my TV to use VPN. Once this has been applied, I check that the rest of my system is connected to my non VPN network. I checked my TV's ip setting and it is as per my VPN. Only problem when I tried to use Netflix, I cant use with this setup. If I remove the redirect internet traffic and flow all my connection through VPN, I can use Netfilx no problems. Is there anything else I need to do? Please advice, thanks.
Options on the router:
https://imgur.com/a/g3V9T
