Hi all,
I have the RT-AX82U -
I have followed all correct settings on how to add the VPN file to the VPN Client.
Once added the file and I click connect everything says its connected.... However... When checking my IP location nothing has changed. Even though I have selected another country for the VPN file example (India) my IP location is still the same.
I don't know what I'm doing wrong, But I have followed all the right settings on how to add the vpn file to the VPN client.
My setup is like this.
I have a modem with an ethernet cable going from a ethernet port into the AX82U WAN PORT (Blue) Internet works everything.. However, Something I find strange is when i am connected to the AX82U via wireless or LAN with my pc and I go to this 192.168.1.1 It brings up my modems internet router page instead of my AX82U Router page... I have to go to router.asus.com ... I feel like even though I have connected my device to the AX82U router ... It's like its using the internet modems settings??
Is there something I need to do on the ASUS router to make the devices that are connected to it just run through the VPN?
I Just want to be able to connect to the AX82U but with VPN activated.. So when I use my xbox or streaming device it uses a different country..
I thought the idea of the OPENVPN on the AX82U was to allow this for devices that cannot install VPN
Thankyou in advance if someone can help
