VPN Selection by Interface
Tom C
Is there an option in this firmware to assign 2.4 Ghz client connections to VPN1 and 5 Ghz client connections to VPN2? Thanks.
No. You would have to implement it manually through scripting. I believe there's a few forum posts discussing this.
Yes I have looked at those posts and the scripting seemed to be beyond my comfort level. Please consider this as a feature request - to be able to select the VPN and interface routing through a menu.
I'd also use the ad-blocking if it were available through the menus.
-Tom
