VPN server issue on v386.9 (RT-AC68U)
paulgj
Hello,
Just upgraded to 386.9 and note the following activity that seems to be new on the VPN status screen. There appears to be constant client connection attemps from a 185.192.74.115 address, it seems like every few seconds the display updates with a new entry.
Wondering if I did something wrong after the firmware update or if there is something else I need to do with regards to the OpenVPN server I have running.
Thank you!
Have you tried to simply reboot the router?
If you run OpenVPN on the default 1194 port, then you will constantly get hit by bots trying to get in. Use a different port to avoid these.
Thank you for the quick replies, the activity stopped after about half an hour or so.
Edit: Now they are back with different IP, I will change the default port
