Vpn server respond to a specific DNS
I'd guess that you'd need to turn off "Advertise DNS to clients" and the add the following Custom configuration:
push "dhcp-option DNS 8.8.8.8"
I use Nordvpn which gives me the option of using their dedicated DNS which prevents data leaks ( so they say). I just go to WAN - Internet Connection where it says Connect to DNS Server automatically. I choose no & input the ip addresses supplied by Nordvpn in the 2 boxes provided. You can choose other dns servers as well such as opendns etc. This is just a way to override the auto connect to ip's default dns which is often Google. That is what Roku, Netflix etc use to verify geolocation. It redflags your connection when ip address doesn't match google dns server. That is where vpn /smartdns proxy configuration plays a role.
Sorry didn't catch that. I guess it would come down to the configuration of the vpn server. Openvpn server settings within the router look basic. That is where a dedicated vpn server would offer more flexibility.
I see an entry Respond to DNS under advanced settings. Not sure what that does. I still think it comes down to settings at the client end. found this link https://www.snbforums.com/threads/openvpn-and-resolving-dns-names-on-vpn-network.31193/ Maybe that will solve the situation?
this method works perfect except you have to turn off advertise DNS to client when pushing a specific DNS because otherwise it notice it conflicts with ISP Dns.
