Solved VPN Server will not start anymore because NTP does not work suddenly !
GSpock
Hi all,
My config looks like this: one main AX86U router (merlin 386.5_2). A secondary AX56U (merlin 386.5_2) router is connected via its WAN port to a LAN port of main router.
This second router, is turned on and off on request, and runs a VPN Server. So far so good, this has been running OK for quite some time.
Today, for whatever reason, the AX56U does not sync its date/time anymore, and the consequences is that the VPN Server cannot start.
On SSH session, the date is indeed not updated anymore. ntp process is running, as I can see by ps -w |grep ntp that giving this result:
2512 xxxadmin 3776 S /usr/sbin/ntp -t -S /sbin/ntpd_synced -p pool.ntp.org -p time.nist.gov -l -I br0
Any ideas, I am really wondering why this is happening now.
Thanks,
GS
How long has the router been on for? I've noticed that if it can't sync immediately it can sometimes take up to 15 minutes.
I suggest you don't use pool.ntp.org as I have found that to be unreliable because of the way the router's ntp process works. Instead try using time.google.com as primary and time.windows.com as secondary.
Many thanks for your quick reply.
Even after 1 hour it does not sync.
I am now going to test with your suggestion with regards to pool.ntp.org .... more to come ...
... no luck with suggested replacement of ntp.pool.org, same issue after another 30 min .... :(
That's very strange. Can you SSH into the AX56U and nslookup time.google.com or ping www.google.com ? In other words, does it have internet access?
Yes, I can SSH:
Server:    192.168.1.1
Address 1: 192.168.1.1 RT-AX86U.WORKGROUP
Address 1: 216.239.35.8 time3.google.com
Address 2: 216.239.35.4 time2.google.com
Address 3: 216.239.35.12 time4.google.com
Address 4: 216.239.35.0 time1.google.com
Address 5: 2001:4860:4806:c:: time4.google.com
Address 6: 2001:4860:4806:: time1.google.com
Address 7: 2001:4860:4806:8:: time3.google.com
Address 8: 2001:4860:4806:4:: time2.google.com
and
ping www.google.com
PING www.google.com (142.250.178.4): 56 data bytes
64 bytes from 142.250.178.4: seq=0 ttl=116 time=24.806 ms
64 bytes from 142.250.178.4: seq=1 ttl=116 time=24.953 ms
64 bytes from 142.250.178.4: seq=2 ttl=116 time=25.220 ms
64 bytes from 142.250.178.4: seq=3 ttl=116 time=24.884 ms
64 bytes from 142.250.178.4: seq=4 ttl=116 time=24.991 ms
64 bytes from 142.250.178.4: seq=5 ttl=116 time=25.333 ms
64 bytes from 142.250.178.4: seq=6 ttl=116 time=25.028 ms
64 bytes from 142.250.178.4: seq=7 ttl=116 time=24.822 ms
64 bytes from 142.250.178.4: seq=8 ttl=116 time=25.075 ms
^C
... I agree, this is very strange since it used to work very well so far ....
Try this:
service stop_ntpd
/usr/sbin/ntp -t -S /sbin/ntpd_synced -p time.google.com -d -n -q
Try this:
service stop_ntpd
/jffs/scripts# service stop_ntpd
Done.
gpadmin@RT-AX56U:/jffs/scripts# /usr/sbin/ntp -t -S /sbin/ntpd_synced -p time.google.com -d -n -q
ntp: 'time.google.com' is 216.239.35.12
ntp: sending query to 216.239.35.12
Alarm clock
and then date gives ...
Sat May 5 07:22:14 CEST 2018
o_O
The plot thickens. You should see something like this:
ntp: reply from 216.239.35.12: offset:-0.002602 delay:0.102284 status:0x24 strat:1 refid:0x474f4f47 rootdelay:0.000000 reach:0x01
ntp: reply from 216.239.35.12: offset:-0.000691 delay:0.099314 status:0x24 strat:1 refid:0x474f4f47 rootdelay:0.000000 reach:0x03
On your AX86U do you have the local NTP server enabled? Do you also have Intercept NTP client requests enabled? If so try turning that off.
Yes, NTP server enabled on AX86U as well as intercept NTP client request.
After changing intercept NTP client request to No, it works OK .... I still do not get why it used to work before, but in anycase I say a big thank you to you for your time and help.
GS
