vpn speeds
admiral2145
I just purchased a rt-ax888u and im trying to get over 100mbit with the vpn...im using ipvanish...are there settings i need to use for the vpn to run at full speed via router? im currently on 16beta1...also its only using about 55% of one of the cpu's.
thx
Use a different VPN server. It will use only one CPU @ 100% maximum (if the server allows it).
