could vpn director be more advanced than vpn fusion?
and ax86u would it be possible wireguard client vpn?
I don't see it, what section in the asus merlin router is it in?It is already.
There is already.
www.snbforums.com
www.snbforums.com
FYIVPN Director is currently for OpenVPN only.
wireguard_manager, the VPN Director GUI rules can be used/imported/translated by wireguard_manager WireGuard ACTIVE Peer Status: Clients 2, Servers 2
1 = Update WireGuard modules 7 = QRcode for a Peer {device} e.g. iPhone
2 = Remove WireGuard/(wg_manager) 8 = Peer management [ "list" | "category" | "new" ] | [ {Peer | category} [ del | show | add [{"auto="[y|n|p]}] ]
9 = Create[split] Key-pair for Peer {Device} e.g. Nokia6310i (creates Nokia6310i.conf etc.)
3 = List ACTIVE Peers Summary [Peer...] [full] 10 = IPSet management [ "list" ] | [ "upd" { ipset [ "fwmark" {fwmark} ] | [ "enable" {"y"|"n"}] | [ "dstsrc"] ] } ]
4 = Start [ [Peer [nopolicy]...] | category ] e.g. start clients 11 = Import WireGuard configuration { [ "?" | [ "dir" directory ] | [/path/]config_file [ "name="rename_as ] ]}
5 = Stop [ [Peer... ] | category ] e.g. stop clients 12 = vpndirector Clone VPN Director rules [ "clone" [ "wan" | "ovpn"n [ changeto_wg1n ]] | "delete" | "list" ]
6 = Restart [ [Peer... ] | category ] e.g. restart servers
? = About Configuration
v = View ('/jffs/addons/wireguard/WireguardVPN.conf')
e = Exit Script [?]
E:Option ==> 12
If you are promoting/using
is that I was told that openvpn uses outdated crypto primers and has a large attack surface. that's true?For now, it's a custom script. It will be integrated into Asuswrt-Merlin after Asus has is ready for Asuswrt.
Thread 1:
Wireguard - Session Manager - Discussion thread (CLOSED/EXPIRED Oct 2021 use http://www.snbforums.com/threads/session-manager-discussion-2nd-thread.75129/)
Thanks to @Odkrys, WireGuard as an alternative to established VPN tunnel protocols OpenVPN and IPSec has been available on some specific ASUS Routers for a while, although the instructions posted by the OP...www.snbforums.com
Thread 2:
Wireguard - Session Manager - Discussion (2nd) thread
This thread http://www.snbforums.com/threads/session-manager.70787/ has now expired. Thanks for the heads-up SNB Forum member @Ubimowww.snbforums.com
Installation via AMTM:
amtm - the Asuswrt-Merlin Terminal Menu - Diversion
diversion.ch
If your question is about stock Asuswrt - you have to wait. Currently in Beta stage. Not released yet.
that's true?
We use essential cookies to make this site work, and optional cookies to enhance your experience.
