WAN Connection: ISP's DHCP did not function properly
Sky1111
Folks, I having WAN disconnect issue and I do not know where the problem really is - router or modem/ISP?
My cable Internet - 35/3 - was activated about a week ago; initially it was all great, but now I am getting constant WAN disconnects. Please help to understand where the problem is!
Setup:
Modem: Thompson DCM476 modem, Software Version: STAC.02.50
Software Model: a81a
Bootloader: 2.3.1
Router: ASUS RT-AC56U, tried latest Merlin firmwares (.40, .39), currently running latest posted ASUS firmware - RT-AC56U_3.0.0.4_374_4561-g5f5c8d8.trx
Full log is attached. Note the connection restoration in the log is due to the router reboot. Key error message:
"WAN Connection: ISP's DHCP did not function properly"
Yet rebooting router OR modem resolves the issue temporarily. Please help!
  • ASUS_Log_April4.zip
Try turning off the modem for about 10 mins to fully reset the existing lease from your ISP.
I find it odd that they renew your lease every hour (3600 secs). A lot of ISPs will assign 24-hours leaves.
Hi Merlin - can't believe you are not asleep at 4am :) - million thanks for reply...
Here is what I did before I saw your reply:
- changed DHCP query to "Normal"
- hard reset DCM476 via rest button to force the modem to rescan the channels
- rebooted the router
I want to leave it to see if that makes any difference. If not, I will unplug the modem for ~30 min
P.S. ISP - Acanac (Rogers)
Setup:
Bootloader: 2.3.1
Hi and first of all ty our own magic-user Merlin ^^
I experienced the same the other day. Never happend before and i've been using Merlin's software the last 12 months updated them as they have been released.
Taken from systemlog:
quote
Apr 3 08:37:41 WAN Connection: ISP's DHCP did not function properly.
Apr 3 08:38:09 WAN Connection: Ethernet link down.
Apr 3 08:38:12 WAN Connection: Ethernet link up.
Apr 3 08:38:12 rc_service: wanduck 292:notify_rc restart_wan_if 0
Apr 3 08:38:12 dnsmasq[446]: read /etc/hosts - 5 addresses
Apr 3 08:38:12 dnsmasq[446]: read /etc/hosts.dnsmasq - 2 addresses
Apr 3 08:38:12 dnsmasq-dhcp[446]: read /etc/ethers - 7 addresses
Apr 3 07:38:12 stop_wan(): perform DHCP release
Apr 3 08:38:12 kernel: Attempt to kill tasklet from interrupt
Apr 3 08:38:12 kernel: br0: port 1(vlan1) entering disabled state
Apr 3 08:38:12 kernel: br0: port 1(vlan1) entering listening state
Apr 3 08:38:12 kernel: br0: port 1(vlan1) entering learning state
Apr 3 08:38:12 kernel: br0: topology change detected, propagating
Apr 3 08:38:12 kernel: br0: port 1(vlan1) entering forwarding state
Apr 3 08:38:14 dnsmasq[446]: read /etc/hosts - 5 addresses
Apr 3 08:38:14 dnsmasq[446]: read /etc/hosts.dnsmasq - 2 addresses
Apr 3 08:38:14 dnsmasq-dhcp[446]: read /etc/ethers - 7 addresses
Apr 3 08:38:15 WAN Connection: ISP's DHCP did not function properly.
Apr 3 08:38:22 WAN Connection: Ethernet link down.
Apr 3 08:38:57 WAN Connection: Ethernet link up.
Apr 3 08:38:57 rc_service: wanduck 292:notify_rc restart_wan_if 0
End quote
I'm using firmware version 3.0.0.4.374.40_0 (Merlin)
Other facts:
Router Asus RT-AC66U
ISP is Telia
Modem Technicolor TG799TSvn v2 (In bridge mode)
After the changes I mentioned above, few hours later:
Apr 5 04:51:44 WAN Connection: ISP's DHCP did not function properly.
Apr 5 04:51:44 stop_nat_rules: apply the redirect_rules!
Apr 5 04:54:35 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Apr 5 04:54:36 rc_service: udhcpc 725:notify_rc stop_upnp
Apr 5 04:54:36 rc_service: udhcpc 725:notify_rc start_upnp
Apr 5 04:54:36 miniupnpd[634]: received signal 15, good-bye
Apr 5 04:54:36 rc_service: waitting "stop_upnp" via udhcpc ...
Apr 5 04:54:37 dhcp client: bound 198.91.144.154 via 198.91.144.129 during 172629 seconds.
Apr 5 04:54:37 miniupnpd[760]: HTTP listening on port 38315
Apr 5 04:54:37 miniupnpd[760]: Listening for NAT-PMP traffic on port 5351
Apr 5 04:54:39 WAN Connection: WAN was restored.
However, the connection was still up...
Merlin
You want to see a really crazy DHCP lease time take a look at AT&T Uverse.
My lease time 10 minutes, that is right, 10 minutes. That means that every 5 minutes we go through the renewal. Now that is crazy. Only time I have seen that done is when there really isn't enough leases for all clients possible.
The connection is solid though. I only use Uverse for Internet and IP phone. Use Dish for TV. Thinking of dropping Dish and just stream.
--bill
Completely different issue. The following two lines:
indicate that either your modem was rebooted, or you have a problem with the Ethernet cable between the modem and the router.
Hi Merlin,
I believe it was me who rebooted the modem at ~8:30am...
However, it seems like changing the setting on router did help... if the disconnects come back, I will move the router from the second floor to the basement next to the modem and will connect it with a short cable..
If you're using DMZ, port forward 67/68 UDP to your router's IP address. Sometimes DMZ can forward renew packets.
Sorry I am not clear: I do have one of the systems on my network in DMZ; do I forward port from that IP address?
Ty mate ^^ sorry for disturbing. But i exp the same ..thought that was it.
the router was up for 1 day and 3 hrs so far, but I do see WAN connection drops and reconnects in the system log.
What does the following mean:
Apr 5 08:27:25 miniupnpd[888]: received signal 15, good-bye
Apr 5 08:27:26 dhcp client: bound 198.91.144.154 via 198.91.144.129 during 3600 seconds.
Apr 5 08:27:26 miniupnpd[957]: HTTP listening on port 48361
Apr 5 08:27:26 miniupnpd[957]: Listening for NAT-PMP traffic on port 5351
Apr 5 08:27:29 WAN Connection: WAN was restored.
Apr 5 09:27:28 WAN Connection: ISP's DHCP did not function properly.
Apr 5 09:27:28 stop_nat_rules: apply the redirect_rules!
Apr 5 09:30:15 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Apr 5 09:30:15 rc_service: udhcpc 995:notify_rc stop_upnp
Apr 5 09:30:15 miniupnpd[957]: received signal 15, good-bye
Apr 5 09:30:15 rc_service: udhcpc 995:notify_rc start_upnp
Apr 5 09:30:15 rc_service: waitting "stop_upnp" via udhcpc ...
Apr 5 09:30:16 dhcp client: bound 198.91.144.154 via 198.91.144.129 during 172631 seconds.
Apr 5 09:30:16 miniupnpd[1031]: HTTP listening on port 41078
Apr 5 09:30:16 miniupnpd[1031]: Listening for NAT-PMP traffic on port 5351
Apr 5 09:30:18 WAN Connection: WAN was restored.
It means miniupnpd was told to restart.
Forward 67/68 to your routers IP.
WAN > Virtual Server
Service name: dhcp1
Port Range: 67
Local Address: 192.168.1.1 (or whatever IP your router has)
Local Port: 67
Protocol: BOTH
Add
Service name: dhcp2
Port Range: 68
Local Port: 68
Protocol: BOTH
Add
Apply.
Service name: dhcp1
Port Range: 67
Local Port: 67
Protocol: BOTH
Add
Service name: dhcp2
Port Range: 68
Local Port: 68
Protocol: BOTH
Add
Apply.
Thanks for clarification - done!
