WAN Dropout/Flap detection & reporting
lianthar
Hi - I have just bought a new Asus RT-AX88u and am running the latest Merlin FW.
I am looking for an easy way to report on all WAN dropouts/flaps? Is there a way to do this? Is there a specific log entry or entries to look for that will show both quick flaps and longer (minutes) long dropouts of the Internet service?
Thanks in advance
L&LD
Part of the Furniture
What's a flap?
L&LD
Did you just make that Wiki entry? :D
RMerlin
Asuswrt-Merlin dev
"port flapping" is actually a known term in networking, it describes when a port keeps alternating between up/down states.
L&LD
Sorry, just trying to make a funny. I knew the Wiki entry was real. :)
But this is the first time I've heard this term.
thecheapseats
I wish there were (distinguishing router fails vs flapping)... due to a less than stellar upstream provider, I've spent more time than I'd like on the cl running down their flapping routes and misconfigured BGP issues before I start looking at the local router on my end...
if you or anyone else has any tips - I'd appreciate hearing them, too...
lianthar
I was hoping someone with advanced knowledge on how to parse the syslog for the right type of entries might be able to advise? Another option I was considering was seeing if my DDNS name could be monitored using an external website monitoring service. Anyone tried that approach?
ColinTaylor
The only relevant entries in the syslog that I can think of are like these:
Dec 1 13:09:27 WAN(0)_Connection: Ethernet link up.
Dec 1 13:09:33 WAN(0)_Connection: WAN was restored.
Although this mostly works for outages that last a reasonable amount of time I've found that it doesn't show the "link down" messages for brief outages (flapping).
lianthar
Yep - same here. I can see brief outages on my connected devices but these don't seem to show as something I can pinpoint in the logs. Longer outages do get ISP DHCP error messages.
I do have dual-WAN enabled now (to a backup modem) and that uses the DNS method to detect a failover state. Maybe that same DNS method could be used to monitor WAN status in general and provide a summary of failures somewhere?
ColinTaylor
You can of course write a custom script that does whatever you want if you're prepared to do the work. For example people have written scripts that email them when there has been a loss of internet. It depends on exactly what you're trying to do. Detecting a lack of internet can be done easily enough with pings, but that's not the same as detecting a flapping port (which I thought was what you wanted).
lianthar
I've come up with a solution of sorts that works for me. The failover detection (using DNS method) for Dual-WAN meets my criteria to detect what I am looking for in terms of dropouts - ie: Detect Interval: Every 5 seconds / Failover Trigger Condition: When the current WAN fails 12 continuous times, failover to Secondary WAN.
When the WAN does failover a DDNS update is forced and that is recorded in the syslog: eg.
Dec 2 11:46:15 inadyn[23380]: Update forced for alias xxxxxx.ddns.net, new IP# xxx.xxx.xxx.xxx
My failover modem uses a different IP range so it is easy for me to see when I have failed over to the secondary WAN link.
So if I write the syslog out to a server and just look for any entries where DDNS updates point to the failover WAN IP range.
Martineau
This SyslogEventMonitor.sh script may get you started....
The crude script continuously monitors Syslog for defined trigger messages, but can be inefficient if you have a busy Syslog i.e. the script will process every message.
You can of course install
to only write the trigger messages to a separate syslog-ng filter file. Subsequently a simple change in the script to monitor the appropriate syslog-ng filter file (rather than Syslog) will improve the efficiency of the script as it will only execute the script's logic when the specific syslog-ng filter file is physically updated.
RMerlin
Asuswrt-Merlin dev
Syslog will on report if the Ethernet link to the modem goes down, or if a PPPoE session is terminated. It won't report if your ISP suddenly stops routing traffic.
