I Just found that it is not possible to configure the 2.5Gbit port of the GT-AXE16000 as a LAN port, some googling tells me Asus thinks this is a feature.... Is this a restriction in the closed source part of the code concerning WAN as might be suggested in the "READ THIS FIRST" section? Or would it be a viable feature request for the Merlin Build?
For me this would make the 2.5Gbit port available for an uplink to an extra Zenwifi Pro XT12, one 10Gbit for uplink to my switch and the other to another zenwifi Pro XT12 (my switch does not support 2.5G.... (although it does work with 10G
"Q: I'm having Dual-WAN related issues. Can you fix it?
A: Most likely not, because part of the code is closed-source, and the rest is scattered throughout hundreds of thousands of lines of code, and next to impossible to understand."
