WAN Status Always 'Not Connected'
bitmonster
No matter what I try for WAN sensing - DNS Probe / Ping / Disable - WAN status is always 'disabled'. Is there anything I can try or look at to isolate the isssue?
I fixed that disconnected error with the ping and dns, you have to set it up correctly you need to set a hostname as in www.google.com and the IP address it provides and for ping it can be an IP address or website.
DNS IP is acquired by pinging a website with command prompt.
Also if you want I can give the details.
