WAN with bridged modem
yep but... I get a public IP with the PPPoE connection. Just confirm that the gateway must be the modem IP
That is not what the example shows?
Hi, walking around seveal problems (it's make me crazy) I found this at Wiki:
https://github.com/RMerl/asuswrt-merlin/wiki/Access-modem-Web-UI-on-WAN-port-(no-script)
Anyboby knows if this setup is with the modem in bridged mode?
I suppose that the answer is not but... I'm not sure how can I set up the gateway of my LAN and my router to the WAN.
It depends on the bridge-mode, kinda, but yes, I think that guide is for bridged modems. (Otherwise, it would be double-NAT, which is not something to encourage.)
A device can bridge PPPoE while still allowing IP access to itself. My Cisco 877 can act as a PPPoE bridge while still allowing access to itself by using the IRB features (Integrated Routing and Bridging).
My Speedstream 4300's bridge-mode button does not allow IP access, unless you configure bridging yourself.
My Sagemcom 1704n allows IP access with it's "quick-bridge" mode.
I have only used my pfSense router with this trick, I have no experience with iptables. I used this guide: https://doc.pfsense.org/index.php/Accessing_modem_from_inside_firewall
Thanks, I'll keep in blank for default configuration.
And... regarding on. What's is exactly this?:
"Advertise router's IP in addition to user-specified DNS" - Will force the DNS ip of the router to the clients?
"Forward local domain queries to upstream DNS" - Will forward LAN DNS queries to the ISP DNS? I understood that this is the default way if a leave the gateway IP in blank.
"Enable DNSSEC support" - It's free? Will be name resolving slower? I never used before.
Thanks a lot!! ;)
