I think I may have corrupted my CFE. I would be glad for someone with RT-AC68U and E1 revision to pull out their CFE.
If you have other revision of the router you can also post your CFE. We can try making an archive of different CFE's.
Here's instruction (it takes only 5 minutes to do, so I would be glad for help). Whole procedure is unharmful.
You will need Putty and WinSCP :
Putty:
WinSCP:
1. In the router web GUI enable SSH in "Administration" - "System" tab.
2. Open Putty SSH connection on port 22 (use your routers LAN IP address to connect)
3. Open WinSCP and connect them to your router using its Lan IP address), In WinSCP select SCP as protocol.
4. In putty type: cat /dev/mtd0 > original_cfe.bin
4. In WinSCP you should be in the /home/root or /root directory hit the refresh icon on right side to see original_cfe.bin.
5. Copy original_cfe.bin form router to your computer by dragging from the right window to your computer in the left window.
6. Please paste original_cfe.bin here on the forum
7. Disable SSH in "Administration" - "System" tab if you had it disabled.
Putty:
Download PuTTY: latest release (0.81)
www.chiark.greenend.org.uk
WinSCP :: Official Site :: Download
WinSCP is a free file manager for Windows supporting FTP, SFTP, S3 and WebDAV.
winscp.net
