wanted to ask for some help
supermorph
question, is there any plans to add a more fleshed out port forwarding ui?
i ask, as i am used to openwrt and dd-wrt and find it sometimes a bit frustrating that asus has left this dumbed down so we cant add ports manually instead of just games or programs in its listings :)
thanks for your time,
des
... asus has left this dumbed down so we cant add ports manually ...
What router and firmware are you using? Is the router configured for Wireless Router mode or some other mode? Generally the port forwarding section is located on the WAN > Virtual Server / Port Forwarding page. Set Enable Port Forwarding to On, then select the Add Profile button to display the Quick Select and Custom Configuration dialog box. Example from a RT-AC68U running 3.0.0.4.386_49703, Custom Configuration section highlighted:
Asus Support article explaining how to setup port forwarding:
[WAN] How to set up Virtual Server/ Port Forwarding on ASUS Router?
If you need Port Trigger see the following:
[WAN] Port Trigger introduction and set up
hello bennor,
I am on a RT-AC88U
and I am running firmware 386.9
thanks for pointing me in the right direction, much appreciated indeed.
ill have a look at this now,
:cool:
