Watchdog script to monitor device availability on local network?
XIII
I want to be notified when one particular device in my local network goes offline. I was first thinking of writing a script on a Raspberry Pi, but then I thought it might be possible on the router (RT-AC86U, running Asuswrt-Merlin 384.13) itself?
My general idea is to ping the device a couple of times (every x minutes) and if all those attempts fail send a push notification via Pushover to my mobile devices.
Does somebody already have a similar script that (s)he wants to share?
Or any tips on how to start from scratch?
Do a forum search that give you a start.
Did that before I posted, but I was not lucky with the search terms I used...
What about to use "pushover" as search word, working for me.
I'm trying this for now; feedback is welcome!
#!/bin/sh
check_reachable() {
    ping -c1 -q -w10 "$1" >/dev/null 2>&1
notify() {
    curl -s \
    --form-string "token=<APP>" \
    --form-string "user=<USER>" \
    --form-string "title=AC86U" \
    --form-string "message=$1 unreachable!" \
    --form-string "sound=siren" \
    --form-string "priority=1" \
    https://api.pushover.net/1/messages.json
for HOST in device1 device2 device3 device4
do
    if ! check_reachable ${HOST}
    then
        notify ${HOST}
    fi
done
where device1, device2, device3, and device4 are (local) hostnames for some devices in my network.
With this line added to services-start:
cru a Reachable "55 * * * * sh /jffs/scripts/check_reachable.sh"
And this line to services-stop:
cru d Reachable
Run script with "set -x" and trace it.
It’s working as far as I know.
Since I’m no script guru I am wondering if this can be improved, and how.
EDIT: Did a real-life test by disconnecting a device just before 19:55 and did get a push notification on my Apple Watch at 19:55 :)
My ASUS RT-AC88U supports IFTTT.
I've used it to detect and alert me when a Roku connects to my WiFi.
It might be able to detect and alert on device disconnects too.
Sent using Tapatalk
#!/bin/sh
check_reachable() {
notify() {
    curl -s \
do
    then
        notify ${HOST}
    fi
done
cru d Reachable
I am not too familiar with scripts, I have the wan notification and firmware update ones running properly and can execute them from a command line to test but when I try to do the same with this one I get
-sh: ./check_reachable.sh: not found
so I am still having some trouble, when I have this line and trigger from a command line nothing happens:
if I simply change it to
I get the pushover notification from the command line but I never actually get notified when the device I am trying to monitor goes offline, do I need to change something in the ping line?
I don't know what you mean by "when I have this line and trigger from a command line nothing happens". All that command does is schedule the script to run once an hour at 5 minutes to the hour. So you have to wait until that time.
