Web Interface Broken and USB shares not showing. 378.51
Learo2000GT
Long time looker and first time poster. I tried searching for the problem I am having. I updated to 378.51 and the web interface is not showing all of the page information, and my my USB shares are not showing up on my network. Do I need to do a factory restore after installing the firmware, or am I missing something else? Thank you in advance for help. Doug
After updating, you should restore the Factory Default settings.
Administration -> Restore/Save/Upload Setting -> Factory default -> "Restore" button
I think you mean Factory Default Restore.
Do not restore previous saved settings into new firmware.
Correct. I was referring to the button labeled "Restore". Context clues should lead to that conclusion but thanks for the clarification, nonetheless.
Administration -> Restore/Save/Upload Setting -> Restore
Unfortunately, the context clues provided are to do a restore saved settings...
You might want to edit your original post then?
Edited. Thanks for helping me avoid any potential miscommunication.
Restore to default context seems to be correct on the router I own.
What model specifically is not?
Maybe it is a language thing? But if I interpreted that way, others may have too.
Seems to be clear now though. :)
