WebGUI / Dual WAN: browser-related issue with .178.15
geko53
I've found an interesting issue using Web GUI in different browsers: when trying to enter the "DUAL WAN" section of WAN with Firefox (14.0.1) or with Google Chrome (21.0) you will find an image that is not the same than that you can find with IE 9 (see attachments).
With FF or Chrome you will not be able to "enable Routing Rules for Dual WAN", as the radio button is disabled. Besides, some fields you can find with IE9 are missing.
With IE9 you will not be able to change the entry for "Secondary WAN" as you wont't find any entries in the choice box. The same behavior (missing entries in the choice box) you will find with the fields "Country / ISP profile rules for Primary WAN" or "Country / ISP profile rules for Secondary WAN".
Strange, isn't it? :confused:
I'm not sure wether this issue could be found in the precedent builds too...
That's weird...on my screen I don't have the Firefox 14 showing under the Dual WAN/ Wan Port Setup like yours does. I'm using version 178.15 as well and Ive got the latest firefox too (14.0.1).
...strange. I can reproduce that issue on different PCs in my LAN...
What does your IE webGUI show? Are your choice boxes for "Secondary WAN" etc. empty too?
I can confirm that too, both Firefox 15 and Aurora are missing the country information, its there on IE10.. I see that many times, some pages will not display on some browsers are fine on others.
D Asus RT-AC86U Dual Wan and IPV6 ASUS N Routers & Adapters 8
