WebPage problem using 374.39.0
dave85
hi community, first i want to say this firmware is amazing is so much better than the buggy asus firmware, but yesterday i have a problem, im touching this firmware like modifying mtu and stuff to check performance, and then some web cant reach, like www.speedtest.net, and i cant be able to login to lol even when i reboot the asus have random issue of connectivity
when i reboot the asus all back to normal this is a bug? or maybe a feature that make this problem?
Regards.
Sounds like you may have changed something that you shouldn't have then didn't change it back?
What I'd suggest is doing a reset to factory defaults, then manually re-enter your settings and see if that fixes your problem. That should help you normalize your settings so that you're at least back to where you started, and you can go from there again if you need to change things for some reason.
can be possible the router loss packet? because sometimes i cant reach some webpage its say not found, and the i refresh and works fine.
Check your DNS configuration if it really says the page cannot be found.
If it's timing out however then it could be something else.
i check the dns and is fine, the dns is the ac68u, i have the same problem if i put in the pc the google dns same problem.
In that case if you really are experiencing packet losses you need to start pinpointing at which level you are losing the packets. Could be a LAN issue, but it could also be a WAN/ISP issue.
Start with a basic, mostly default configuration. Playing with the MTU will create problems if you set incorrect values. The vast majority of users do not need to touch this setting.
