i'm trying to run an aimesh of two 86u's and one 68u. so i setup my old and trusty 86u as a main and the two other routers as nodes. everything goes well,the mesh is working for a while but then all devices connected on the 2.4 band on the node 86u are disconnected. when i try to connect them again i sometimes get a wrong password or they connect but with 26mbps speed and run very slow. i tried disabling all the known options that cause problems some time(beamforming,Airtime Fairness,Multi-User MIMO) but the problem is still there. after a reset everything runs well again for a random period of time before the problems starts again. i then tired using the 86u as an access point with different ssid's running on sepetrate channles but i still get the same problems. i though my second 86u which was a replacment of a faulty one is faulty as well but switching the old 86u with the new one gave me the same results, now the new one is working fine as a router and the old one is having problems as a aimesh node or an access point.
meanwhile my 68u is running fine whether as a mesh node or an access point. i'm running a wired backhaul with the 2.4 band running on 20Mhz of course. i tried factory reseting everything,clearing nvram, tried different combination of firmwares old and new official and custom. i also tried runing one 86u(tried both of them) with the 68u both in mesh and access point mode and it ran well. it's just those 2 86u's that won't play well together. i'm not running any scrips(don't know how actually
) and not doing anything out of the ordinary. i'm out of ideas here and i appreciate any help.
