Weird device Belkin out of nowhere
Logi
I have the RT-AX86U, connected to Frontier Fiber on the WAN port, and T-Mobile Home Internet to the 2.5G port, no other device connected to any of the LAN ports.
Sometimes when I go to the list of devices connected I will get this one, I have no Belkin device at home, and it says it is a WIRED device, could it be that the Cold-Standby T-Mobile Gateway connected to the 2.5G port is showing up randomly?
Did you configure the 2.5G LAN/WAN port to be a 2.5G WAN port, or is it still the default LAN port5?
OE
So far as I'm aware, and I'm sure that if I'm wrong someone will correct me, but the client names we see are often not specified by the client. Instead, these names often need to be guessed by the router using published tables on the allocation of MAC addresses to vendors. Sometimes that info is wrong or confusing!
Yes, but in this case a MAC lookup says the MAC prefix is of Belkin. I suspect the entry is from when the box was connected to the 2.5G port before it was configured for 2.5G WAN... the router then gave it a DHCP IP address and logged it(?)
OE
The T-Mobile Internet gateway is a Nokia device, definitely not Belkin
Definitely not T-Mobile, too, I suppose. :)
Lookup any MACs on it to see who they belong to.
Wireshark · OUI Lookup Tool
The router assigned an IP to it... it was on your LAN. Only you know the likely culprits.
OE
Lookup tool says: Belkin International Inc.
Then Belkin/Linksys is probably the OEM behind the Ethernet port bits.
The client lists are often out of sync. I would not worry about an expired entry... it will go away until the next time you reset the router and 2.5G becomes LAN5 again until you configure it otherwise.
OE
