Western Digital GoFlex 3TB mounting issue
davekoob
Getting the following in my logs when I plug in my 3TB GoFlex drive:
Router shows it as 'Unmounted' USB Icon in the top right shows "USB Function is Disabled"
Tried reflashing FW - on latest 3.0.0.4.270 FW as of last night.
Drive mounts fine and comes up in Windows 8 - ran checkdisk on it last night before trying it again in the router. Let it sit plugged into the router for 8 hours last night in case it needed to do its own checkdisk or whatever.
And the logs:
Jan 30 08:03:16 kernel: usb 1-1.1: USB disconnect, address 3
Jan 30 08:03:16 notify_rc : restart_nasapps
Jan 30 08:03:16 FTP Server: daemon is stoped
Jan 30 08:03:16 rc_service: restart_nasapps is waitting restart_nasapps...
Jan 30 08:03:16 Samba Server: smb daemon is stoped
Jan 30 08:03:17 FTP Server: daemon is stoped
Jan 30 08:03:17 Samba Server: smb daemon is stoped
Jan 30 08:05:01 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 4
Jan 30 08:05:01 kernel: usb 1-1.2: configuration #1 chosen from 1 choice
Jan 30 08:05:01 kernel: scsi1 : SCSI emulation for USB Mass Storage devices
Jan 30 08:05:03 kernel: scsi 1:0:0:0: Direct-Access Seagate GoFlex Desk 0D18 PQ: 0 ANSI: 5
Jan 30 08:05:03 kernel: sd 1:0:0:0: [sda] 732566645 4096-byte hardware sectors (3000593 MB)
Jan 30 08:05:03 kernel: sd 1:0:0:0: [sda] Write Protect is off
Jan 30 08:05:03 kernel: sd 1:0:0:0: [sda] Assuming drive cache: write through
Jan 30 08:05:03 kernel: sda: sda1
Jan 30 08:05:03 kernel: sd 1:0:0:0: [sda] Attached SCSI disk
Jan 30 08:05:03 kernel: sd 1:0:0:0: Attached scsi generic sg0 type 0
Jan 30 08:05:03 hotplug[793]: USB /dev/sda1(ntfs) failed to mount at the first try!
Jan 30 08:05:03 kernel: ufsd: use builtin utf8 instead of kernel utf8
Jan 30 08:05:11 kernel: ufsd: use builtin utf8
Jan 30 08:05:16 hotplug[793]: USB /dev/sda1(ntfs) failed to mount at the first try!
Jan 30 08:05:16 kernel: ufsd: use builtin utf8 instead of kernel utf8
Jan 30 08:05:22 kernel: ufsd: use builtin utf8
HELP!!!!
Try flashing with version 3.0.0.4.266.24 Beta of my firmware, and see if it works better for you. I have applied some kernel patches that should help with large hard drives, it will help with _some_ USB enclosures (some simply won't work under Linux however).
Still shows WD GoFlex 3TB drive as 'unmounted' and "USB Function is Disabled" in the top right...
Logs for your viewing pleasure:
Dec 31 18:00:07 syslogd started: BusyBox v1.20.2
Dec 31 18:00:07 kernel: klogd started: BusyBox v1.20.2 (2013-01-24 00:24:30 EST)
Dec 31 18:00:07 kernel: Linux version 2.6.22.19 (root@asus) (gcc version 4.2.4) #1 Thu Jan 24 00:48:19 EST 2013
Dec 31 18:00:07 kernel: CPU revision is: 00019749
Dec 31 18:00:07 kernel: Found an ST compatible serial flash with 32 64KB blocks; total size 2MB
Dec 31 18:00:07 kernel: Determined physical RAM map:
Dec 31 18:00:07 kernel: memory: 07fff000 @ 00000000 (usable)
Dec 31 18:00:07 kernel: memory: 08000000 @ 87fff000 (usable)
Dec 31 18:00:07 kernel: usbcore: registered new interface driver usbfs
Dec 31 18:00:07 kernel: usbcore: registered new interface driver hub
Dec 31 18:00:07 kernel: usbcore: registered new device driver usb
Dec 31 18:00:07 syslog: module ledtrig-usbdev not found in modules.dep
Dec 31 18:00:08 syslog: module leds-usb not found in modules.dep
Dec 31 18:00:08 kernel: SCSI subsystem initialized
Dec 31 18:00:08 kernel: Initializing USB Mass Storage driver...
Dec 31 18:00:08 kernel: usbcore: registered new interface driver usb-storage
Dec 31 18:00:08 kernel: USB Mass Storage support registered.
Dec 31 18:00:08 kernel: ufsd: driver (8.6 U86_r187446_b122, LBD=ON, acl, ioctl, rwm, ws, sd) loaded at c0211000
Dec 31 18:00:08 kernel: NTFS (with native replay) support included
Dec 31 18:00:08 kernel: optimized: speed
Dec 31 18:00:08 kernel: Build_for__asus_n66u_2011-10-27_U86_r187446_b122
Dec 31 18:00:08 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Dec 31 18:00:08 kernel: ehci_hcd 0000:00:04.1: EHCI Host Controller
Dec 31 18:00:08 kernel: ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1
Dec 31 18:00:08 kernel: ehci_hcd 0000:00:04.1: EHCI Fastpath: New EHCI driver starting
Dec 31 18:00:08 kernel: ehci_hcd 0000:00:04.1: irq 6, io mem 0x18004000
Dec 31 18:00:08 kernel: ehci_hcd 0000:00:04.1: USB 0.0 started, EHCI 1.00
Dec 31 18:00:08 kernel: usb usb1: configuration #1 chosen from 1 choice
Dec 31 18:00:08 kernel: hub 1-0:1.0: USB hub found
Dec 31 18:00:08 kernel: hub 1-0:1.0: 2 ports detected
Dec 31 18:00:08 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Dec 31 18:00:08 kernel: ohci_hcd 0000:00:04.0: OHCI Host Controller
Dec 31 18:00:08 kernel: ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 2
Dec 31 18:00:08 kernel: ohci_hcd 0000:00:04.0: irq 6, io mem 0x18009000
Dec 31 18:00:08 kernel: usb usb2: configuration #1 chosen from 1 choice
Dec 31 18:00:08 kernel: hub 2-0:1.0: USB hub found
Dec 31 18:00:08 kernel: hub 2-0:1.0: 2 ports detected
Dec 31 18:00:09 kernel: usbcore: registered new interface driver usblp
Dec 31 18:00:09 kernel: drivers/usb/class/usblp.c: v0.13: USB Printer Device Class driver
Dec 31 18:00:09 kernel: usb 1-1: new high speed USB device using ehci_hcd and address 2
Dec 31 18:00:09 kernel: usb 1-1: configuration #1 chosen from 1 choice
Dec 31 18:00:09 kernel: hub 1-1:1.0: USB hub found
Dec 31 18:00:09 kernel: hub 1-1:1.0: 4 ports detected
Dec 31 18:00:09 kernel: usbcore: registered new interface driver asix
Dec 31 18:00:09 kernel: usbcore: registered new interface driver cdc_ether
Dec 31 18:00:09 kernel: usbcore: registered new interface driver net1080
Dec 31 18:00:09 kernel: usbcore: registered new interface driver rndis_host
Dec 31 18:00:09 kernel: usbcore: registered new interface driver zaurus
Dec 31 18:00:09 kernel: br0: starting userspace STP failed, staring kernel STP
Dec 31 18:00:09 kernel: vlan1: dev_set_promiscuity(master, 1)
Dec 31 18:00:09 kernel: device eth0 entered promiscuous mode
Dec 31 18:00:09 kernel: device vlan1 entered promiscuous mode
Dec 31 18:00:09 kernel: usb 1-1.2: new high speed USB device using ehci_hcd and address 3
Dec 31 18:00:09 kernel: usb 1-1.2: configuration #1 chosen from 1 choice
Dec 31 18:00:09 kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Dec 31 18:00:10 kernel: device eth1 entered promiscuous mode
Dec 31 18:00:10 kernel: wlc_phy_cal_init_acphy: NOT Implemented
Dec 31 18:00:11 kernel: device eth2 entered promiscuous mode
Dec 31 18:00:11 kernel: device wl0.1 entered promiscuous mode
Dec 31 18:00:11 kernel: br0: port 4(wl0.1) entering listening state
Dec 31 18:00:11 kernel: br0: port 3(eth2) entering listening state
Dec 31 18:00:11 kernel: br0: port 2(eth1) entering listening state
Dec 31 18:00:11 kernel: br0: port 1(vlan1) entering listening state
Dec 31 18:00:11 kernel: br0: port 4(wl0.1) entering learning state
Dec 31 18:00:11 kernel: br0: port 3(eth2) entering learning state
Dec 31 18:00:11 kernel: br0: port 2(eth1) entering learning state
Dec 31 18:00:11 kernel: br0: port 1(vlan1) entering learning state
Dec 31 18:00:11 kernel: br0: topology change detected, propagating
Dec 31 18:00:11 kernel: br0: port 4(wl0.1) entering forwarding state
Dec 31 18:00:11 kernel: br0: port 3(eth2) entering forwarding state
Dec 31 18:00:11 kernel: br0: port 2(eth1) entering forwarding state
Dec 31 18:00:11 kernel: br0: port 1(vlan1) entering forwarding state
Dec 31 18:00:11 stop_nat_rules: apply the redirect_rules!
Dec 31 18:00:11 WAN Connection: ISP's DHCP did not function properly.
Dec 31 18:00:11 kernel: scsi 0:0:0:0: Direct-Access Seagate GoFlex Desk 0D18 PQ: 0 ANSI: 5
Dec 31 18:00:11 kernel: sd 0:0:0:0: [sda] 732566645 4096-byte hardware sectors (3000593 MB)
Dec 31 18:00:11 kernel: sd 0:0:0:0: [sda] Write Protect is off
Dec 31 18:00:11 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Dec 31 18:00:11 syslog: Password for 'admin' changed
Dec 31 18:00:12 kernel: sda: sda1
Dec 31 18:00:12 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Dec 31 18:00:12 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Dec 31 18:00:12 hotplug[532]: USB /dev/sda1(ntfs) failed to mount at the first try!
Dec 31 18:00:12 kernel: ufsd: use builtin utf8 instead of kernel utf8
Dec 31 18:00:12 notify_rc : start_nat_rules
Dec 31 18:00:12 kernel: nf_conntrack_rtsp v0.6.21 loading
Dec 31 18:00:12 kernel: nf_nat_rtsp v0.6.21 loading
Dec 31 18:00:13 notify_rc : stop_upnp
Dec 31 18:00:13 rc_service: stop_upnp is waitting start_nat_rules...
Dec 31 18:00:16 WAN Connection: WAN was restored.
Dec 31 18:00:16 notify_rc : start_nat_rules
Dec 31 18:00:16 rc_service: start_nat_rules is waitting start_nat_rules...
Dec 31 18:00:17 dnsmasq[595]: started, version 2.63 cachesize 1500
Dec 31 18:00:17 dnsmasq[595]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack
Dec 31 18:00:17 dnsmasq[595]: asynchronous logging enabled, queue limit is 5 messages
Dec 31 18:00:17 dnsmasq-dhcp[595]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Dec 31 18:00:17 dnsmasq[595]: read /etc/hosts - 3 addresses
Dec 31 18:00:17 dnsmasq[595]: using nameserver 75.75.76.76#53
Dec 31 18:00:17 dnsmasq[595]: using nameserver 75.75.75.75#53
Dec 31 18:00:17 RT-AC66U: start httpd - SSL
LOGS CONTINUED IN NEXT POST
Continuation of Logs
Dec 31 18:00:18 crond[598]: crond: crond (busybox 1.20.2) started, log level 8
Dec 31 18:00:18 syslog: Generating SSL certificate...
Dec 31 18:00:18 syslog: SNet version started
Dec 31 18:00:19 miniupnpd[628]: HTTP listening on port 58115
Dec 31 18:00:19 miniupnpd[628]: Listening for NAT-PMP traffic on port 5351
Dec 31 18:00:19 Samba Server: daemon is started
Dec 31 18:00:19 disk monitor: be idle
Dec 31 18:00:21 nmbd[643]: [2010/12/31 18:00:21, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Dec 31 18:00:21 nmbd[643]: Samba server RT-AC66U is now a domain master browser for workgroup WORKGROUP on subnet UNICAST_SUBNET
Dec 31 18:00:22 kernel: ufsd: use builtin utf8
Dec 31 18:00:22 kernel: Ebtables v2.0 registered
Dec 31 18:00:23 start_nat_rules: apply the nat_rules!
Dec 31 18:00:24 notify_rc : start_upnp
Dec 31 18:00:24 rc_service: start_upnp is waitting stop_upnp...
Dec 31 18:00:24 miniupnpd[628]: received signal 15, good-bye
Dec 31 18:00:25 notify_rc : stop_ntpc
Dec 31 18:00:25 rc_service: stop_ntpc is waitting start_upnp...
Dec 31 18:00:25 syslog: SNet version started
Dec 31 18:00:25 miniupnpd[694]: HTTP listening on port 52359
Dec 31 18:00:25 miniupnpd[694]: Listening for NAT-PMP traffic on port 5351
Dec 31 18:00:25 dnsmasq-dhcp[595]: DHCPREQUEST(br0) 192.168.1.182 5c:0a:5b:4e:53:14
Dec 31 18:00:25 dnsmasq-dhcp[595]: DHCPACK(br0) 192.168.1.182 5c:0a:5b:4e:53:14 android-232bcf9a25b11920
Dec 31 18:00:26 notify_rc : start_ntpc
Dec 31 18:00:26 rc_service: start_ntpc is waitting stop_ntpc...
Dec 31 18:00:27 dhcp client: bound 67.167.202.196 via 67.167.200.1
Jan 31 08:55:27 notify_rc : restart_diskmon
Jan 31 08:55:27 disk monitor: be idle
Jan 31 08:55:27 notify_rc : restart_upnp
Jan 31 08:55:27 miniupnpd[694]: received signal 15, good-bye
Jan 31 08:55:27 syslog: SNet version started
Jan 31 08:55:27 miniupnpd[702]: HTTP listening on port 53546
Jan 31 08:55:27 miniupnpd[702]: Listening for NAT-PMP traffic on port 5351
Jan 31 08:55:29 nmbd[643]: [2013/01/31 08:55:29, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Jan 31 08:55:29 nmbd[643]: Samba server RT-AC66U is now a domain master browser for workgroup WORKGROUP on subnet 192.168.1.1
Jan 31 08:55:29 hotplug[532]: USB /dev/sda1(ntfs) failed to mount at the first try!
Jan 31 08:55:29 kernel: ufsd: use builtin utf8 instead of kernel utf8
Jan 31 08:55:34 kernel: ufsd: use builtin utf8
Jan 31 08:55:37 kernel: eth1: received packet with own address as source address
Jan 31 08:55:37 dnsmasq-dhcp[595]: DHCPREQUEST(br0) 192.168.1.3 4c:eb:42:62:a9:c1
Jan 31 08:55:37 dnsmasq-dhcp[595]: DHCPACK(br0) 192.168.1.3 4c:eb:42:62:a9:c1 Koob-HPLT
Jan 31 08:55:41 nmbd[643]: [2013/01/31 08:55:41, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(392)
Jan 31 08:55:41 nmbd[643]: Samba name server RT-AC66U is now a local master browser for workgroup WORKGROUP on subnet 192.168.1.1
Jan 31 08:56:00 crond[598]: time disparity of 1096735 minutes detected
Is there some sort of action I can take if there was a 'dirty' remove from the RT-AC66U ? I've submitted for a replacement from Amazon since this DID work right out of the box... Not sure if the dirty remove was before the FW upgrade or after.
Any pointers would be great.
Thanks,
Koob
> 2TB support is limited on this router. Some USB drive will flat out fail to work under Linux in general.
