Flipmode11
Hello guys,
Just a topic about the *real* good software called "WFC" (Windows Firewall Control) originally by Binisoft (now free under Malwarebytes). It is REALLY good and you just need to make sure you go through settings and enable Notifications so you can allow/block etc. Plus gives you ability to block inbound and outbound connections much more easily, plus monitor connection log, etc.
Basically, I was wondering if anyone could please test exporting their WFC rules (Options » Rules » Export Windows Firewall Rules)
Upon import, it shows a progress bar and then after a few seconds then states operation / restore successful.
However all the rules are exactly as they were prior to import.
Reboot. Nothing has changed. No rules have been imported.
Reset Rules > Yes.
Import Rules
Nothing changes! Just default WFC rules (or default Windows rules).
I don't think the feature works... Or, perhaps there is a corruption in my rules? Nope. Cannot even restore default blank rule backup!!!
Could someone please give this a try and see whether the rules are correctly restored? (e.g. delete one unimportant rule).
Thank you!
Reset Rules > Yes.
Import Rules
Thank you!
