What causes this? May 19 02:04:32 kernel: Unhandled fault: alignment fault (0x92000061) at 0x0000000
nyxagamemnon
Router is GT5300 (asus) Here's the log.
May 18 15:15:25 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f41fed73
May 18 16:06:24 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f45ff34f
May 18 16:27:25 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f48ff773
May 18 17:11:08 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f44c65e3
May 18 17:25:04 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f47ff4df
May 18 18:01:30 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f43fec6f
May 18 18:12:25 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f45c5c33
May 18 18:21:38 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f45ff313
May 18 18:42:33 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f41ff25f
May 18 18:49:15 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f42ff313
May 18 18:58:52 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f41ff2d7
May 18 19:23:36 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f41ff1e7
May 18 19:45:14 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f43fed4b
May 18 20:11:44 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f43fec1f
May 18 20:29:19 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f41fec33
May 18 21:10:05 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f40fec83
May 18 21:27:03 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f43fefa3
May 18 22:00:50 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f42fef67
May 18 22:44:36 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f47fefcb
May 18 23:18:37 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f41dacd3
May 19 00:03:26 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f48fee4f
May 19 00:29:02 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f47db2af
May 19 01:16:28 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f40fee27
May 19 02:04:32 kernel: Unhandled fault: alignment fault (0x92000061) at 0x00000000f42fedc7
I have the same issue with this garbage router. My advice, return it for the Netfear X10 R9000.
