what does mean RTK
XIYO
I didn't speak English well, so I used Google Translate.
Please point out that you have not selected the right category. I will correct it correctly.
If you look at the router's tools menu, 5-8 are RTK. What does this mean?
Thank you in advance to everyone who answers.
RMerlin
Asuswrt-Merlin dev
The RT-AC88U has two separate switches: one built-in Broadcom switch, and an external Realtek switch, which handles the extra four ports.
XIYO
Thanks for the respected Merlin answer.
Why are there 2 switches due to hardware limitations? (E.g. bandwidth) Or could the RTK do something else?
RMerlin
Asuswrt-Merlin dev
Because the builtin switch inside the BCM4708 only has four ports (plus one internal). A second switch is needed to increase the number to 8 ports.
Zastoff
Found this thread
