What firewall setting if any should I add/change for bridge1
jea101
RT-AC66W (U)
Merlin 378.56_2 firmware
I created vlan3 and br1
I added vlan3 to br1
I assigned IPv4 and IPv6 addresses to br1
I enabled router advertisement br1
My current firewall start script
#!/bin/sh
touch /tmp/000fwstarted
iptables -I INPUT -i br1 -j ACCEPT
iptables -I FORWARD -i br1 -j ACCEPT
ip6tables -I INPUT -i br1 -j ACCEPT
ip6tables -I FORWARD -i br1 -j ACCEPT
exit
My current service start script
#!/bin/sh
# touch /tmp/000brstarted
# add vlan 3 to eth0
vconfig add eth0 3
ifconfig vlan3 up
# add vlan 3 to br1
brctl addbr br1
brctl addif br1 vlan3
ip -4 addr add 192.168.zzz.1/24 dev br1
ip -6 addr add 2001:470:xxxx:yyyy::1/64 dev br1
ifconfig br1 up
# move ports 2 and 3 to vlan3
robocfg vlan 1 ports "1 4 8t"
robocfg vlan 3 ports "2 3 8t"
exit
My current dnsmasq.conf.add
interface=br1
dhcp-range=br1,::,constructor:br1,ra-stateless,64,7200s
dhcp-option=br1,option6:dns-server,[2001:470:xxxx:yyyy::251],[2001:470:xxxx:yyyy::252],[2001:470:xxxx:yyyy::1]
admin@RT-AC66W-B518:/jffs/configs# cd ../scripts
With my current settings I pass this Ipv6 firewall test for PCs on either br0 or br1.
http://www6.chappell-family.co.uk/cgi-bin6/ipscan-fast-txt.cgi
Windows PCs on br0 respond to the tests IPv6 ping
PCs on br1 don’t respond to the tests IPv6 ping
