Depending on the router/client performance encryption sometimes can impact throughput, but encryption is the only way to secure your wireless, unless you implement enterprise security(RADIUS Server auth). MAC address filtering is just as or weaker than WEP, MAC addresses can be spoofed or copied allowing anyone who wanted in, to get in with little effort. WPA2 + AES is best with 64 hex or 63 alphanumeric or 63 ASCII random characters to form 256 bit hash, but both router/client must support it. TKIP is what WPA uses and is a little weaker but still pretty secure using the same random 256 bit hashes. The only challenge today is preventing the wireless encryption from being dictionary attacked, there has been movement on dictionary attacks performed simply because you have a common SSID and there are hash algorithms built to attack such common SSIDs. So a unique SSID and a long random character 256 bit hash key is best security you can provide yourself at the moment. Try making up an unique SSID then use these random generated keys: https://www.grc.com/passwords.htm . Good Luck!
Excellent information, thank you.
I have been using WPA/TKIP on my 802.11n router because i had some 802.11g bridges. It looks like the only way to fix throughput is to upgrade to 802.11n bridges, then everything will be capable of running WPA2/AES and my tthroughput problems will be over.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
