B? G? It's time to get rid of legacy and move to AC/5 GHz. I don't buy anything that can't support AC/5 GHz. We only have four devices left on N/2.4 GHz...Wii U and tablet and both are rarely used, a mobile phone that only connects to WiFi for larger system updates and a crappy iphone. And also have two rarely used streaming N/5 GHz devices that don't have wire run to them. Everything else is wired or AC.
You could always use it as a switch for older g devices or even an AP for those devices!It's sad that solid gear like that can't find a good home. I mean, it's basically a router version of the wap54gs I use around here for simple itoys access.
Not everyone is in the same situation as you...
I personally would feel guilty giving older, insecure equipment to anyone knowing these home router manufactures typically abandon updates after 2-3 years.
Linksys
Product: WRT54GL
Hardware Version: 1.0 & 1.1
Classification: Firmware Release History
Release Date: Jan 22, 2016
Last Firmware Version: 4.30.18 (build 6)
Linksys is still updating the firmware for the WRT54GL...
http://www.linksys.com/us/support-article?articleNum=148652
Code:Linksys Product: WRT54GL Hardware Version: 1.0 & 1.1 Classification: Firmware Release History Release Date: Jan 22, 2016 Last Firmware Version: 4.30.18 (build 6)
Yup, over a year since an update. It's a niche, tinkerer device with a certain type of crowd keeping it alive...enough on that.
Not if it's in the DMZ in gateway mode - since it's NAT'ed (NAT is a firewall) and no ports opened, it's perfectly safe
No router is completely 'safe'. If someone wants to break in, they will. The question is who is going to really care about a wrt54 in this day and age?Incorrect. NAT will firewall inbound connections into the WRT54G, but not the outbound ones. So, WRT54G gets direct access to the primary gateway, which it can try to compromise, and gain control of. Once primary gateway is compromised, the whole LAN segment connected to the primary gateway becomes compromised.
NAT is only an inbound firewall, not outbound. I've used such double NAT setup in the past for specific configuration needs (where people behind the second router had to be isolated from people between both routers, yet still have full access to a printer located between the two routers).
Hackers should also jump all over open ssids that are locked down with mac restrictions only, but I never see such things. It all depends on where you're deploying the ap as well.Hackers are going to jump like flies over honey at the sight of a WEP AP broadcasting in the open. That's the real worrying part.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
