Solved What VPN Director rule should i use to be able to connect outside my home to my VPN provider?
brodas
Well, what I want is to connect to my VPN provider outside my home. When I connect with Wireguard it shows me the public IP of the ISP and what I need is to connect to the VPN provider.
Currently if I am at home, it works with the VPN provider without any problem. But if I want to do it away from home it doesn't work anymore.
I don't know if I should use some rule to make a bridge? I have tried everything but it does not work.
In case it is not clear, I will try to explain it in the following screenshot:
My rules in VPN Director are as follows:
Thanks to your time.
Try
Localip: 10.6.0.2/32
Remoteip: leave blank
Iface: wgc2
This covers a single server clients. Change localip to 10.6.0.0/24 for all server clients if needed.
