What's better of these 2 routers (wifi6)
L&LD
Part of the Furniture
RT-AX58U
wowo
the ax58u will be downstairs as the main one and one of these two will be upstairs and I don't know which one to choose
L&LD
English, please. :)
wowo
I use google translator:p
But the point is, I need router and I don't know which one to choose from the 2
L&LD
My answer hasn't changed.
I would suggest neither. Buy another RT-AX58U for the best experience.
If you won't need the fastest speed possible over a VPN in the foreseeable future (then it would be either an RT-AC86U or RT-AX88U as your main router for the AES-NI performance increase they offer VPN connections (from about 40Mbps on the RT-AX58U up to 250Mbps on the suggested models, depending on both ends of the ISP's up/down speeds/capabilities). :)
