When I enable pixelserv-tls I can't use AiMesh
  • ATTENTION! You'll notice a Prefix dropdown when you create a thread. If your post applies to one of the topics listed, please use that Prefix for your post. When browsing the thread list you can use the Prefix to filter the view.
ComputerSteve
When I enable pixelserv-tls I can't use AiMesh. My nodes do not receive an IP Address. As soon as I turn off pixelserv-tls & adblocking in diversion my nodes receive IPs. I'm running the latest build of Merlin 386.1_2
SomeWhereOverTheRainBow
how big is your block file? how many domains are you trying to block? this is important because if you are trying to block too many domains, Aimesh will fail(along with all other dhcp dnsmasq functions). Alot of Domains+Pixelserv-TLS+AiMesh= One hella mess.
ComputerSteve
So i'm using two - Large is the main / minimal is the second
ComputerSteve
So I upgraded back to the latest firmware 386.1_2 I also disabled the alternative blacklist, & I set the blacklist blocklist to standard. I now notice on the latest firmware this seems to make my AImesh nodes work. I still think something is going on because on the previous firmware I had Large / Minimal selected, & didn't have any problem.
ComputerSteve
So this is continuing to happen. If I turn off pixelser-tls AiMesh almost immediately starts working. If I don't disable pixelser-tls my nodes never appear & they don't connect properly either.
most users have opted not to use pixelserv-tls for these reasons and have switched to the 0.0.0.0 blocking. I think it has fallen out of popularity with some setups. I had a good run with it with AImesh, but like you pointed out DHCP failure occurs with Aimesh Nodes. This occured with me running over a million domains. I have not experienced this with running it on smaller list. I imagine Pixelserv-tls is just not keeping up with the advancements of everything else.
ComputerSteve
Whats the 0.0.0.0 blocking? Also yes I notice the same thing if I just leave everything as default (meaning standard block list, no alternative block list with additional pixelserv ip) It works correctly. Hopefully this gets addressed because I love Diversion. Can you use that with 0.0.0.0 blocking lol
elorimer
FWIW, I'm not having this issue with an 86U and Medium list. Pixelserv still rocks for me, and even though what it serves up is mostly rejected, it is rejected instantly.
ComputerSteve
On both my RT-AC3100 & RT-AC5300 I have the problem when I try them on the latest merlin firmware with Full blocklist & alternative list enabled minimal. I am going to try with Pixelserv disabled.
