Where should an AP be connected?
connectwizard
Hi everyone,
I have Ubiquiti Gateway, switch and AP and I’m trying to figure out the best way to connect the access point. Should I plug it directly into the cloud gateway, or is it better to connect it to my pro switch that’s connected to the gateway using SFP+ port?
The access point will be plugged into a 2.5gbps port regardless but I'm not sure about the latency and other things. I don't need the wireless clients to be able to communicate with each other, only the internet so I assume eventually the traffic will have to go through the gateway.
Thank you
T A Little Fuzzy - How many devices can be connected? General Wi-Fi Discussion 16
