Where to run ethernet cable in a 3 storey house?
imwired
Here's a bit of background:
I've got 2 routers: DLINK 655 and 625
I plan to use the 655 as the main router on the 2nd floor (top) of the house and the 625 is going to be used as an AP in the basement.
I want to run a wire from the router to the AP using a CAT5e cable.
I've got the option of using the central vacuum vents or the cold air return.
Which of the two would be better? or is there another option?
Any thoughts/suggestions?
imwired
Either method will work just fine. Good example of creative thinking!
As Tim says – either option is fine. FWIW – I'd lean toward the cool air return as long as it's dry. Mostly just for the silly reason that electronics like cold :)
