Which is better?
Will10101
I have been given a DGA4231 and a XMG3927-B50A. Can anyone tell me which is better? I can’t find much info on the DGA4231 so im guessing it’s worse.
Thanks in advance
Both are xDSL home gateways with similar specifications. Test both and see which one works better with your ISP or provides better Wi-Fi, in case you use the gateways as wireless routers and not modems only.
