Which of these switches for gaming?
niemion
So Starcraft 2 is out and I'm going to host a LAN-party this weekend. My router has only four LAN ports, so I figure I need a switch.
Which one of these switches would you recommend?
Switches at my local hardware pusher
I'm going to need 10 ports and my budget is 800 kr which equals 140 dollars. If it can be done cheaper, then that's fine too :p
Any 10/100 Mbits switch should do the job. Since gigabits swtich is low also, I would go for that.
Take note that the lan support for starcraft 2 as been pull out. It's battle.net only and require an internet connection.
Also the website have a series of article how to prepare for that kind of even:
http://www.smallnetbuilder.com/content/view/24248/53
