Which Wireless N Access Point is better for N coverage
tipstir
Tim,
What about the Trendnet N router with wireless access
TEW-652BRP (Version V1.0R)
TEW-632BRP (Version A1.0R)
TEW-631BRP (Version 3.0R)
Are any of these stable when you did your test for N access. I know the top one on the list above is dirt cheap. I just need N access on the upper floor to stay at 100% level. A single DIR-655 seems to keep it at from 96-100% in N mode only.
I tested only the TEW-632BRP. The Wireless charts show it has a lower throughput vs. path loss curve than the DIR-655. I can't tell you whether you will get a better signal level.
