Skynet Why does Skynet ban perfectly legit websites
wizin
2 examples are
I have the newest version and these are just 2 examples, some other sites don't load
2 examples are
Application.exe or Website.com Is Blocked​
Don't worry, tracking down false positive bans was at the core of design. Generally speaking you can follow these steps to find (and whitelist) anything incorrectly on your Blacklist!
  1. Enable Logging;
sh /jffs/scripts/firewall settings logmode enable
  1. Open the blocked application/website and use the command;
sh /jffs/scripts/firewall debug watch
  1. Now look for a flood of [BLOCKED - OUTBOUND] coming from the same IP. This most likely will be the IP you are looking for if its being spammed in large numbers.
  1. Copy the IP following "DST=" it should look something like this;
DST=175.115.37.52
  1. Double check the IP is not actually something that should be banned, use a search tool like alienvault. If its related to a domain additional "Associated Domain" information should be printed beneath the log.
  1. Great we have confirmed we found the IP of the blocked website/application we are looking for, lets whitelist it!
sh /jffs/scripts/firewall whitelist ip 175.115.37.52
Correct me if I’m mistaken, but I assume much of this is default to Skynet to begin with and can visually be viewed within the UI or whitelisted in the CLI without invoking the direct commands. Essentially you’re just ensuring he has firewall logging enabled, and set to debug mode. Which is the most important part.
UI simply has the benefit of quickly accessing Alien-vault but has the disadvantage of only showing you the top 10 unique hits where the cli has more flexibility.
I like your instruction simple and to the point.
Thanks so much so now I've been unbannnig sites via UI, I refresh and it works but some like https://www.spigen.com/ didn't, they only work when I disable skynet. Any help sir @Adamm
Thanks, so odd I have been having a hard time logging into staples.ca, I unbanned it yet wouldn't work. I ping it and damn domain shows as shops.myshopify.com I unban this and then it works.
