Why no traffic monitor in AP mode?
connorm
why is there no traffic monitor in AP mode... seems kinda silly to me
i have been forced to use my router in Router mode but manually configure to act like an ap and i still can not ping 8.8.8.8 or have a ntp request go through
maybe traffic monitor should be added to AP mode? with IP monitoring aswell?
Because it doesn't...
AP mode doesn't do that, the feature is dependent on the device being in Router mode...
not at all, im using it as an ap in router mode and using it
i have used IP monitoring on tomato aswell using it an an AP
DD-WRT breifly, not sure if there was IP monitoring but traffic monitoring
i understand if its not the gateway then it might not be accurate on the traffic numbers
thats not nessesarrily what i want
i wanna be able to look and see which device/who is using 2.4/5GHz
this is 100% possible
It registers layer-2 traffic?
The traffic-monitor is always there, the GUI just hides it. Just manually browse to that particular *.asp file. "Main_TrafficMonitor_daily.asp" maybe?
