Wierd problem on an AC86U
charlesbuzz
Hello
Since friday, I have this wierd issue where all my devices, even if they are connected to my AC86U (wireless log and DHCP leases prove it) act very slow or drop and reconnect and the signal range drop a lot.
Connected devices work correctly
This is not a new installation, I have this setup working correctly since more than 6 mounth
Speedtest not working even if I have 2 bars signal on my iPhone
The problem happend on 2 differents router , both RT-AC86U (no Aimesh, not connected at the same time, I bouth the second one to diagnose) both have the same problem
The configuration look like this
Router: RT-AC86U
Firware: 3.0.0.4.386.42643 and now 3.0.0.4.386_44470
Smartconnect
2.4ghz channel 6 (20/40 mhz)
5 ghz channel 149 (20/40/80 mhz)
Multi-User MIMO only on 5ghz band
no Airtime Fairness for both bands
no Aimesh node
type of devices: iPhone/iPad/PC/Wemo/Mysa/RainMachine/google home/Chrome cast etc...
where do I start to find this problem ?
thanks for your help
Use 20 MHz for 2.4 GHz and 80 MHz for 5 GHz (no DFS channels).
RT-AC86U routers are sensitive to high ambient temperature. When the CPU reaches 100C the thermal protection shuts down cores. You can check the CPU temperature in stock Asuswrt by logging in GUI and clicking on the link below:
router.asus.com/ajax_coretmp.asp
What else is running on the router? Do you have external USB storage attached, what type and what it is used for?
What else is running on the router? Do you have external USB storage attached?
this is what I get
fanctrl_info = ; curr_cpuTemp = "84.648"; curr_rxData = fanctrl_info[3]; curr_coreTmp_2 = fanctrl_info[1]; curr_coreTmp_5 = fanctrl_info[2];
what is the normal temperature of operation for tis cpu?
nothing else is running
There is no normal. It varies with ambient temperature. Yours is fine, above 90-95C is a concern.
Did you check what's going on with Wi-Fi channels around? Use your preferred Wi-Fi Analyzer app. Is the issue present on both 2.4GHz and 5GHz bands?
it is defenetly a 2.4 ghz problem if I refer to the ping test
5ghz to lan around 10-20 ms
5ghz to 5ghz around 20-50 ms
5ghz to 2.4ghz around 500-1000 ms with drop packets
lan to 2.4ghz around 500-1000 ms with drop packets
This router has bad reliability history. One of the many common complaints is 2.4GHz radio failure. Many folks on this forum lost one or more AC86Us. What I found inside and possible failure causes is here. Where did you get the second unit from? Is it a new router or used?
is it possible that I have a Wifi device that is causing this problem ?
Yes. Start disconnecting devices on 2.4GHz band one by one and test again. Hopefully you find a bad client, not a bad router.
My solution as a precautionary.
