Wifi 7 MLO seems buggy on BE96U
Ryandodo
I Have configured my Home Ap which is asus RTBE96U with MLO enabled.
I created an entirely separate network (an MLO SSID) , as you could see here
I tried to connet my station to my home AP
Asus RTBE96U with good Signal strength -45dbm and it's connected to 6G band successfuly as MLO connection.
I saved the password of my network for my station for the next time to remember this network to connect to it immediately ..
Now i toggle my wifi button off - it disconnected from network but now Im far away from the the router like signal strength -70dbm , I toggled then my wifi button ON back so I expect to connect to my mlo network in 5g or 2g , but what is happenning that my station not able to connect to network at all , neither to 5g nor to 2g , station starts association to my mlo network but it fails to connect successfully and AP deauth my station.
If Im at very good signal strength like -50dbm and station on this case connected with 6g then toggling my wifi button off and on without moving , my station still able to connect back to my mlo network and it connects back in 6g.
Maybe its known issue on asus when MLO feature enabled? Maybe I missed some mlo configs at AP side related to MLO?
What could be the reason for why such AP refusing my station to connect to 5g/2g?
If you haven't done so already, you may want to review the various other discussions on MLO as a number of people are having issues with it.
Some have found turning the MLO feature off helps.
When I first bought the BE86 the default was enabled for MLO but Asus has now changed that to disabled.
Yes. Read though the various threads that search link returns. Several people had issues with, or traced to, MLO and they found turning it off help with their issues. As always YMMV for your use case.
I mean if I turn mlo disable then station connect as non mlo mkde ( connection will not be mlo) , so that wouldnt help me much
Having just put mine together, in general some of my older devices have trouble with it, consequently, some of those same devices had issues with Smartnet on my AX router/nodes when I had them set for both the 5Ghz and 2.4Ghz.
So what I have done, and for me it's working well, so far, is create band specific networks using Customized Network profile and toggleling that last button, "Use same subnet as main network"
to get around it. The newer devices on the MLO network, the older devices on the Custom. I have two a 5 and a 2 (for 2.4) for the sake of brevity. I will make a new onw with both 2.4Ghz and 5Ghz non Wifi 7/MLO as time permits and migrate all the outlilers to it and hopefully they can work with both bands, if not it stays as is. The laptops and iPhones work fine with MLO so far, but as always YMMV
I also have some IoT networks but the HP printer I have wants to be on the same subnet as the computers/phones that print. Still workng out which devices can live on the separate subnet. but it's only been a week, so it's a work in progress...
So to let MLO works/to try , what exactly I need to configure at AP?
Assume ssid name is Bakla_Mlo , sowhat i need to configure?
I built a new network, using this profile
With a separate (not the same name Bakla_Mlo, maybe call it Bakla, your choice) SSID, with 2.4 Ghz and 5 GHz, and chose for it to used the same subnet, but that's me and my needs, yours may be diferent as this is NOT a one size fits all capability. Or you could try with the three band, WiFi7 and no MLO point is you got options, so whatever works for you.
Read/see the earlier post and make sure that's what you want.
Yeah so you mean to configure each band for different ssid? Its the not mlo network yeah?
Not exactly, an MLO based SSID, and a separate SSID using the Customized Network profile, and try with 1, 2, 3, bands see see what works in your case. You can do per-band if you like, whatever works for you. Point is again, you got options. I did per band for 2.4 and 5Ghz because (separate from my MLO and Guest Network) that's how my network was setup and I didn't want to revisit all the devices, simpler for me. I can adapt it as I go along.
I've been running MLO on my two BE96U routers, since the past weekend. So far, everything has been rock solid. Unlike with the BE92U routers I had.
Nothing has dropped off or rebooted since I enabled MLO. The only thing I did notice was in the log. And an entry will periodically show up that says "Can't add zero MAC". That is the only change I noticed when I enabled MLO. Otherwise, all my 2.4Ghz, 5Ghz, and 6Ghz devices are still working without dropping off the network.
I read that t a log entry like that could be related to an IoT device. But, all my devices are still working properly.
I did notice that my BE96U thinks there is a missing node in my setup (and I saw no way to delete it from the web browser or Asus App). Which must be left over from when I copied my BE92U settings file over to the BE96U. So, at some point, I need to input everything again from scratch. But, since everything is working great, I'm in no rush to do it.
