Wifi drains my huawei p9 battery
I think that problem has to be solved at the phone end. Sounds like it is not sleeping properly.
This could be caused by an app.
Easy fix is to shut off the phone Wi-Fi at night. Also if you noticed that the power drain started after installing a particular app, delete the app.
This is kind of normal - the various apps are checking in...
FWIW - iphone 5 (my work phone) on LTE will run over the weekend, but put it on WiFi, and by Saturday afternoon it's needs a charge...
Sometimes having set a static IP for the phone with certain ports forwarded to that IP can cause a significant drain to the phone as well.
