WiFi dropping laptop-wlceventd_proc_event(511)
Rob Q
Hi, my mom keeps telling my that internet connection has been lot but when I check the cable modem, everything is working properly and my other devices on WiFi are connected and online.
I've went to check the router logs and I found this.
The router is running Firmware:386.9
Feb 13 16:36:53 syslog: wlceventd_proc_event(511): eth2: Disassoc XX:XX:XX:XX:XX:2B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:-66
Feb 13 16:36:53 syslog: wlceventd_proc_event(494): eth2: Deauth_ind XX:XX:XX:XX:XX:2B, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Feb 13 16:36:53 syslog: wlceventd_proc_event(530): eth2: Auth XX:XX:XX:XX:XX:2B, status: Successful (0), rssi:0
Feb 13 16:36:53 syslog: wlceventd_proc_event(559): eth2: Assoc XX:XX:XX:XX:XX:2B, status: Successful (0), rssi:0
Feb 13 16:36:53 dnsmasq-dhcp[8448]: DHCPREQUEST(br0) 192.168.1.53 XX:XX:XX:XX:XX:2B
Feb 13 16:36:53 dnsmasq-dhcp[8448]: DHCPACK(br0) 192.168.1.53 XX:XX:XX:XX:XX:2B DESKTOP-8H4IVOM
Feb 13 16:37:28 syslog: wlceventd_proc_event(511): eth2: Disassoc XX:XX:XX:XX:XX:2B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:-67
Feb 13 16:37:28 syslog: wlceventd_proc_event(494): eth2: Deauth_ind XX:XX:XX:XX:XX:2B, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Feb 13 16:37:28 syslog: wlceventd_proc_event(530): eth2: Auth XX:XX:XX:XX:XX:2B, status: Successful (0), rssi:0
Feb 13 16:37:28 syslog: wlceventd_proc_event(559): eth2: Assoc XX:XX:XX:XX:XX:2B, status: Successful (0), rssi:0
Feb 13 16:37:28 dnsmasq-dhcp[8448]: DHCPREQUEST(br0) 192.168.1.53 XX:XX:XX:XX:XX:2B
Feb 13 16:37:28 dnsmasq-dhcp[8448]: DHCPACK(br0) 192.168.1.53 XX:XX:XX:XX:XX:2B DESKTOP-8H4IVOM
Feb 13 16:37:44 syslog: wlceventd_proc_event(511): eth2: Disassoc XX:XX:XX:XX:XX:2B, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:-66
Feb 13 16:37:44 syslog: wlceventd_proc_event(494): eth2: Deauth_ind XX:XX:XX:XX:XX:2B, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Feb 13 16:37:53 syslog: wlceventd_proc_event(530): eth2: Auth XX:XX:XX:XX:XX:2B, status: Successful (0), rssi:0
Feb 13 16:37:53 syslog: wlceventd_proc_event(559): eth2: Assoc XX:XX:XX:XX:XX:2B, status: Successful (0), rssi:0
Feb 13 16:37:53 dnsmasq-dhcp[8448]: DHCPREQUEST(br0) 192.168.1.53 XX:XX:XX:XX:XX:2B
Feb 13 16:37:53 dnsmasq-dhcp[8448]: DHCPACK(br0) 192.168.1.53 XX:XX:XX:XX:XX:2B DESKTOP-8H4IVOM
At first I thought that it was the signal strength but the rssi of my phone was around -72 and it wasn't dropping at all.
Could it be the WiFi radio of her Acer laptop starting to fail? It's on the 5 GHz band. I am unable to connect it with a wired connection.
Here are the temp readouts.
curr_coreTmp_wl0_raw = "50°C";
curr_coreTmp_wl0 = (curr_coreTmp_wl0_raw.indexOf("disabled") > 0 ? 0 : curr_coreTmp_wl0_raw.replace("°C", ""));
curr_coreTmp_wl1_raw = "53°C"; curr_coreTmp_wl1 = (curr_coreTmp_wl1_raw.indexOf("disabled") > 0 ? 0 : curr_coreTmp_wl1_raw.replace("°C", ""));
curr_coreTmp_wl2_raw = "disabled"; curr_coreTmp_wl2 = (curr_coreTmp_wl2_raw.indexOf("disabled") > 0 ? 0 : curr_coreTmp_wl2_raw.replace("°C", ""));
curr_coreTmp_wl3_raw = "disabled"; curr_coreTmp_wl3 = (curr_coreTmp_wl3_raw.indexOf("disabled") > 0 ? 0 : curr_coreTmp_wl3_raw.replace("°C", ""));
curr_cpuTemp = "80"; fanctrl_info = "";
Rob Q
I've turned off "802.11ac Beamforming" and manually set the control channel and channel width.
Rob Q
Changed the "preferred band" to 5GHz, "wireless mode" to a/n/ac, and "roaming aggressiveness" to lowest. Maybe that will help.
