Wifi Enabling NAS
gregplc40
Greetings!
I have recently purchased a nice NAS for my home office. Unfortunately getting wired Ethernet to it from my home router is more challenging than I thought. I have a Buffalo TeraStation 1400R NAS. I am wondering if there is anyway I can get it on my wireless home network? It has USB ports, so I'm wondering if there is anyway I can use a USB to Ethernet Wifi adapter on it. Or am I better off just throwing a cheap wifi router directly on the unit and wirelessly bridge the two routers?
TIA,
Greg
Why not try HomePlugs?
Also check with Buffalo if they support Wifi interfaces. Some NAS like QNAP's actually support them.
Greetings!
TIA,
Greg
I believe the stock firmware limits the usb ports to external drives/printers.
It is possible to install Debian on these devices which would allow you to do anything you'd like with the usb port including adding a wireless adapter.
If you are interested, the installer and instructions can be found at:
https://github.com/1000001101000/Debian_on_Buffalo
