clever_duck
Hello,
I've got RT-AX92U one running downstairs connected to the modem and the other upstairs connected via AiMesh. Over the past week or so wifi keeps dropping for some reason. I don't recall anything changing.
If I upload the syslog would someone be able to point me in the right direction? Not sure if uploading log files is allowed here.
I have a fairly complex home network here with over 25 devices, a NAS drive, a Pi Hole, etc. Router not pointing to PI Hole, used as stand alone for now.
It's dropping on all devices so I'm sure it's going to be the router than the device.
I've rebooted both the router and the modem many times, still same issue.
Currently on fw 3.0.0.4.386_43084
Sep 6 20:49:56 kernel: thermal cooling_device1: turn off CPU#1
Sep 6 20:49:56 kernel: IRQ6 no longer affine to CPU1
Sep 6 20:49:56 kernel: CPU1: shutdown
Sep 6 20:49:58 kernel: process 20009 (dcd) no longer affine to cpu1
Sep 6 20:49:59 kernel: process 4015 (dcd) no longer affine to cpu1
Sep 6 20:50:08 kernel: process 4018 (dcd) no longer affine to cpu1
Sep 6 20:50:08 kernel: process 4016 (dcd) no longer affine to cpu1
Sep 6 20:50:19 kernel: wl1: random key value: BD19A61BDD0201253C14002B707C4D587E6EDFBAF22B0D3E1AA8C7DF879D9858
Sep 6 20:50:19 wlceventd: wlceventd_proc_event(491): eth6: Deauth_ind 28:7F:CF:257:8A, status: 0, reason: Disassociated due to inactivity (4), rssi:0
Guessing it's getting too hot that is one of the reasons. But it has been working ok up until recently.
