WiFi only works on channel 1 RT-AC68U
ralong
Hi. I i bought used RT-AC68U
And my 2.4 wifi only works on channel 1. On every other channel I cant even connect to the network. On all of my devices.
That's problematic because channel 1 is very congested where i live.
Did anyone have the same problem and knows how to fix it?
I used original firmware, changed it to merlin 386.3_2 and still have this issue.
L&LD
Part of the Furniture
ralong
No. After 2 days the problem returned.
Resetting the router to defaults and connecting every device again every 2 days is not something i want to do
L&LD
Please provide clear, specific, and unambiguous steps you did after fully resetting the router.
If you follow the link and suggestions below (exactly) and the issue(s) continues, it points to a hardware problem at that point.
Fully Reset Router and Network
ralong
1.Changed MAC address of the router
2.Changed passwords and name of wifi network
3.Disabled 5g wifi
4.Set 2,4 wifi power to power saving
5.manually set wifi chanel to 11
Yes i tried setting the power higher or lower doesn't help
L&LD
So, to be clear, you did not use the suggested defaults in the first link I posted above?
1. Why are you changing the MAC of the router?
2. Did you use only alphanumeric SSID's (8 characters min) and passwords (16 characters max) with no special characters, punctuation, spaces or smiley faces?
3. Why?
4. Why?
If you manually set the Control Channel to channel 11, why are you stating only channel 1 works?
ralong
1.my isp only accepts 1 mac
2.yes
3.dont use
4.I live in one room apartment
Because when i set it to channel 1 it works. and on every other channel it doesn't. That's literally what I wrote in the first post.
L&LD
What I'm reading is that you don't use the recommended, best practice, defaults.
Try following the suggestions to the letter and seeing if the router is stable then.
In an apartment-type environment, the 5GHz band is usually preferred (more airtime available, and greater throughput). While I can understand your concern for the unstable 2.5GHz band performance, have you tried using the 5GHz band?
Have you tested for any length of time without your specific customizations? The power-savings setting may be the issue here (on its own).
ralong
I have 12 IOT devices that use only 2.4 network. I have a PC connected via Ethernet. I have no need for 5ghz network. Really.
At this point I am sure its a hardware issue. Because laying router on its back(not standing up) fixed the issue again.
So probably when i was resetting the router last time, me picking it up fixed the issue, not the resetting part.
So the question is how to fix this issue.
L&LD
If it's hardware, then a new or replacement is the only option.
L&LD
Do you know what's broken? If you do, then you can consider fixing them.
The issues you describe could be the power supply (may be worth checking with a new/known good one), a faulty IC, or a resistor and/or cap, etc. Then, having the skills needed to carefully remove and replace them without burning out other components in the vicinity.
Far more cost-effective to just buy another router (if you must pay for labour for the above).
In general, few consumer electronic 'appliances' are fixable, for the layperson.
