Nothing showed at the time it happened. After reboot:What did the router's log file show?
I can't comprehend that file. There are no end-of-line characters. Can you post a properly formatted version of it?Nothing showed at the time it happened. After reboot:
May 5 01:05:04 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10 - Pastebin.com
Pastebin.com is the number one paste tool since 2002. Pastebin is a website where you can store text online for a set period of time.pastebin.com
sorry if there is some unnecessary info in there.
Are you using the DFS channels on the 5 GHz band? If so try 20, 40, 80 MHz with Auto channel. You may have been hit by RADAR.As the title says, Wireless signal suddenly dropped, lights were still blue and I‘ve already rebooted the router, so everything is normal. Could this be a red flag in the near future?
Router: ac66u_b1 on 386.5_2 Merlin, had the router for almost 2 years
OK I've repaired that log file but it only covers the two minutes after you rebooted the router. So it contains no relevant information.I can't comprehend that file. There are no end-of-line characters. Can you post a properly formatted version of it?
Roughly what time did the problem occur?
sorry about that, should be fixed. 7:51 PM, around that.I can't comprehend that file. There are no end-of-line characters. Can you post a properly formatted version of it?
5GHz is on channel 48, might try auto channel, 2.4GHz is on auto.Are you using the DFS channels on the 5 GHz band? If so try 20, 40, 80 MHz with Auto channel. You may have been hit by RADAR.
This is basically the only bit of info that showed up at 7:50 ; Apr 13 19:50:39 RT-AC66U_B1-65D0 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2OK I've repaired that log file but it only covers the two minutes after you rebooted the router. So it contains no relevant information.
Can you post a properly formatted log file that covers the period the problem occurred please.
Can you post more than one line so we can try and understand context of the messages and compare them to our routers. Something that covers 10 minutes either side of the problem occurring.this is what showed up at 7:50 ; Apr 13 19:50:39 RT-AC66U_B1-65D0 kernel: [tdts_shell_ioctl_stat:256] Recv ioctl req with op 2
i get them frequently so i brush them off.
Was this a one time "event" or a regular occurance? From what you've posted, you seem to be overly concerned about something that a has happened once and b) may be a simple configuration or environment issue.As the title says, Wireless signal suddenly dropped, lights were still blue and I‘ve already rebooted the router, so everything is normal. Could this be a red flag in the near future?
Welcome To SNBForums
