WinSCP alternative
^Tripper^
Not exactly a router specific question but related (apologies if this isn’t the place to post this.)
I see WinSCP being the recommended application around here. Anything similar for macOS? I’ve googled, downloaded and tried but nothing seems to work; ie, they don’t connect and I can’t access the router with those.
Cyberduck
Available for free from their website (with donation optional) or for a sensible price in the Mac App Store
Mac Terminal has scp command line build in too.
It does sftp which should work just the same
I see. I can get cyber duck to work as a ftp client but not scp; which is what I need to get to the base firmware.
Just install entware and then sftp and cyberduck will give you access to the whole f/w the same as scp but over sftp
If you end up needing another alternative, something like WebDrive could be worth a shot. There's a free trial, and it also supports SFTP so it would be a good fit for you.
When I had a Mini, I just used Wine and WinSCP
Mac has scp built into the terminal. (Not a GUI but the command line is not hard)
scp /users/YOUR_MAC_USERNAME/Desktop/Source_File.txt admin@192.168.1.1:/jffs/scripts/Destination_File.txt
You can even drag the srouce file after typing scp into the terminal so it will populate that path automatically.
MobaXterm is another good one. Has integrated SSH clients, supports multiple windows. Not sure I could live without it nowadays. YMMV -> https://mobaxterm.mobatek.net/
